... would you have made different decisions as far as how you approached racing, or your choice of builds, or... ???
I would have never built and raced a 1970 Baracuda 4 speed with a Hemi in NHRA stock on a 9 inch wide slick
I should have weighed that car first as far as how much weight on the front tires and rear tires with me in it
It had 2160 Lbs. on the front tires and 1280 lbs. on the rear without me in it back in 1976 before NHRA required the drivers weight in the drivers seat
I never raced that car again after weighing it that day
That car had a minimum weight of 3440 Lbs. with out the driver after a run back then
