Ok going to give the TV 100% applied a test and see what that does. If that doesn’t do anything does anyone know where about a a crack is common to form on the VB so I can have a look and see if that’s the issue.
If I find no cracks and the TV cable doesn’t fix it I am going to take the trans out and completely go thru it like a rebuild to make sure I don’t have a planetary or something stupid going out possibly. If that’s all good I guess I will just order a full manual valve body from somewhere any suggestions on where to get one. Has to be standard pattern not reverse.
