Hey Fernando, watching your videos looks like that shock rebound is too loose. Rear shocks can't keep tires planted at ground and that's causing tire bouncing. Maybe ceramic clutch can be another factor for cause this. As you said that you are using old tires, I would start changing tires for brand new tires like 28x10 or 28x10.5.
Good luck and keep us informed!
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
