Does anyone have the correct floor hole location measurements for the front buckets on a 69 Road Runner? I puchased the car last fall and the floor has been replaced at some point, and whomever installed the seats went a bit nuts with the drill, as I have two locations for each of the four (8) holes for driver and passenger seat. Both my seats 'look' wrong when viewed from the front as they tend to both lean toward each other. This makes for poor balance when going around corners and freeway on/off ramps. I removed the wonky brackets someone installed for more leg room, but now I want to get them planted properly in the correct location. If I get the correct measurement for the outside front and rear hole, the inners should follow suit. Can anyone help with some measurements? As always, any help is appreciated. Thanks!
