Originally Posted By polyspheric
Can't follow the text, they refer to "adding 1/2" to the stroke", using the stock rods (no offset), and 505" with 4.00" is just under 4.500" bore - not something you would do.
They welded the journals to get to 4.250 stroke with the stock rods
