If you're on a budget, a couple of 67 mm On3 ball bearing turbos would work well. http://www.on3performance.com/shop/on-3-performance-67mm-ceramic-ball-bearing-turbocharger/ You didn't specify a HP goal, but something in the 61MM to 70MM range should work with that size motor.
