I'm putting together a basically stock 360 mag with a good set of heads and a custom ground cam.the package will go in a 72 dart for street and strip.I'm new to the turbo world and I'm wanting to build a twin turbo setup. I only plan on spinning it to 6000 and want to run 10lbs-12lbs of boost without a lot of lag...can someone please tell me which turbos I need to buy before I buy the wrong ones?
