You need some gear with the 4 speed to get it off the line. Are you shifting at 7g? If you are that’s not helping et either. That thing should probably be shifted around 6-6200 with standard port window.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
