Thanks for all the replies,
Cab-The drag radials are dead hooking at this point, maybe a turn. They are spinning as much hitting second gear, once the engine is building steam.
60s in the 1.5x area would be great!!!!
SG Cuda - yup they sure would. Going from 28" tires to 26" should reduce the effective gear ratio to 3.8, so that will help some
EchosSixMike- I dont know about the carb. AndyF said he seen 20-30 hp going to a dominator because of a superior spray pattern. My carb isn't making any vacuum even at 7k.
FurryStump- I was told by a local carb shop he estimates it close to 1080 cfm
Dom- Yea it is in future plans. It will require removing the hood for clearance. That, and probably an electric booster pump?
I am going back out to TNT with 26" tires, without the hood, a 2" spacer, and play with timing and jetting.
I also just got a FBO box and coil to replace the orange box. I was getting some breakup over 6k.
Hopefully the driver will be better.
