I was told by many E85 users to use retracted gap plugs in my E 85 bracket motor, I do As far as blower motors I was told the same thing on not using projected gap plugs in them, I have found out since then that on blown gas hemi motor the projected gap plugs use under 12.0 lbs. of boost live a long time if the fuel and timing are close to correct
