i will have to look at the schematic, but probably a ground, 12v at all times, ign, and maybe a crank feed from ignition switch. it will also have 3 relays incorporated in it. Oh yeah, and 12v to your elec fuel pump...
I just need the harness that is for the engine.
It should have, injectors, coils, TP sensor, crank sensor, distributor pick-up, IAC, ECT, IAT, & 3 plugs or 1 large plug for the PCM (depending on year).
It would be best to have the harness off of the engine you are going to use. There are suttle differences in connectors through out the years.
Starting at the end of next week, I will be able to do them. This is not my full time job, just make a little extra money, and help people out with these mopar EFI swaps.
You can call me with questions... 618-978-9426.
Justin
