2 things come to mind, 1. slide the fitting back and check the flair for cracks or pits. 2. did you flair it with an AN flair tool? they are 37* not the standard 45*. either one of those will cause it to leak..
These are both fittings I purchased from Earls, I didn't make any of the flairs, perhaps I missed a step? I never even heard of a flair tool...
are you using braided line or a hard line? if it's a hard line they have to be flared.
