Ok.
Short block fill is on my list.
I'm having a hard time finding rods to use because of the pistons.
Must be 1.123-1.125 length. (edit 6.xxx)
Must have .927 small end diameter
Can be either 2.125 or 2.10 big end dia.
Must have big end width of .927
Most all I find that would work have a .940-.945 width.
How hard is it for the crank grinder to open up for rod side clearance?
Either that or I buy a mopar sb rod and have the small end bushed.
Is that less expensive?
Scat 9000 cranks are only $300ish.
If I bought one of those it would be a 4" stroke and I would have to throw everything else out the window. LOL
Boost will be my cubes. :-)
