Well, a 742 is MUCH more forgiving given your scenario than a 489... But it still takes a LOT of torque..240lbs if I recall correctly. Not easy to do, but the difference between an undertorqued 742 and a 489 is massive in terms of potential howl/whine. Meaning I don't think your torque on the pinion nut is the issue.
