You can kind of see it on the passenger side firewall back there. I needed a pretty big open space to mount it as I have a Y block attached it (dual feed to the FITECH throttle body, deadheaded at the throttle body and have the return out the bottom of the regulator).
FYI, PER NHRA rules, you can't mount the regulator on the firewall. If you ever plan to race it, you'll want to move that.
