Mr P Body,
Didn't you run a small block with a mechanical roller for a while that did a fair bit of street duty also?
Yeah.. I ran it for about 600 miles.. then I
swapped to a SFT thinking the injection didnt
like the big duration but that wasnt the issue
EDIT
that cam and lifters were in another SB and it
is still fine.. both the cam and lifters.. I pulled
it out and tried a SFT.. sorta sorry I did...
with that roller in it and 10.4 compression it
made 590 hp on the dyno.. with the way I'm
starting to get the injection to work I would
believe it would be in the 600+ HP on the street
in a semi light car(2900#)
