one more thing to check,i had two csr sheilds that the bolt holes didnt line up.you have to actually strap it down and make sure the bolts go STRAIGHT thru when the shield is tight,its a real pain when you get it all put together and every thing is perfect except one stinkin bolt hole is off.
