Hi Tim! I fit mine in the stock tunnel but it was a PITA. Peen the seam, cutting holes for the bellhousing bolts is almost mandatory, and cut the tabs off your trans. Another important thing is make sure nothing is touching it. If it gets any heavy gouges, cuts or scrapes it won't pass recert and will only be good for 5 years.
