Originally Posted By poorboy
If the new rear tires are still as close to the inside box floor as the earlier picture shows, your going to have some serious tire rub. To assume a leaf spring axle doesn't move side to side a bit is a bad assumption. There needs to be at least 3/4" between the widest point on the side of the tire, and any body structure. At 3/4". some rub may occur, but less then 3/4" damage can happen. Years ago I had a couple sidewall damaged tires and a tore up inner fender to prove my point. Gene
They had about 3/4" before. Now there is over 1.25" clearance. The extra width pulled the tire bulge away from the inner wheel well. I narrowed the rear width specifically for these wheel specs.
-78 Utiline (5.7 Hemi)
