Well, the alternator wasn't charging because the voltage regulator was bad. Had an original on hand that fixed it.
Struggling to get those old stamped steel valve covers to seal. Any recommendations?? Done them twice now and no luck. Tried the regular cork and the thick high temp both with Ultra Gray sealer. They aren't slipping out.
-78 Utiline (5.7 Hemi)
