I looked closer & saw the nylon tubing so that is a mech gauge. As you know it can't be driven with it that low. I would pull the dist & intergear & drill prime it & see what develops. Was the PSI OK before? any changes made that might be bringing this on? with the dist out you can see if the rear gallery plug is in place. holler back with any news
