You might see if you have a good frame and alignment shop nearby. They are usually a bit sharper than the local chain stores who deal with Honda's and Toyota's.
Back in 94 when I finished My Charger I took it to the closest place which was a goodyear store. The guy worked on it for about 4 hours, gave me a print out etc. When leaving the parking lot I almost took out a pole due to steering wheel not returning. I then took it to a frame and alignment shop that I normally used. He asked if I had tried aligning it myself to which I said No, Why did you ask? he responded with it wasn't too bad for an eyeball job. 45 Minutes later I drove out and the car hasn't been touched since.
