A pusher fan in a shroud which is covering much of the radiator will NOT be as effective as a pusher without the shroud. If you're going to stick with a pusher then remove the shroud... otherwise put the fan on the engine side of the radiator with the shroud like it should have been done in the beginning.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
