Originally Posted By Supercuda
16 inch electric fan on outside of radiator on a shroud pulling air from engine compartment
That is your problem. You are trying to pull air out of the engine compartment with a fan on the outside.
You need to put the fan inside and pull air INTO the engine compartment.
x2
