All the Holley software can be accessed here:
https://www.holley.com/support/resources/#Fuel_InjectionSounds like your laptop may have a corrupted software installation. You should first save your current global folder somewhere so it won't be touched. Then completely uninstall the Holley software using the "Control Panel", and remove the Holley folder from "My Documents", and the Holley folder on the "C:Drive" (Program Files, Holley folder). Then install from a fresh download.
If you choose to upgrade to V4 you should also read the V4 Overview.
IDLE RPM: As TRENDZ said you have to go through the IAC setup procedure. Sounds like your mechanical throttle screw is holding open the plates. Remember you must do a TPS Autoset whenever you change the mechanical throttle settings.
I will move my one file and delete the holley file and install
the V4.... this use to idle right at 1000 rpm... when I first
started the learn mode it was down to 800 but I believe that
the engine was just that fat.. after reving it a few times and
the cloud came out of the pipes it started to lean out and the
revs picked up.... I forget where you do the IAC reset. but
I guess I can look it up in the help area... I'm getting a
little better at finding the different screens now that I
have been playing(no changing anything but just looking)..
by the way I pulled all of the V2 files straight from the disc
that came with the unit
