"Get from ECU" means "getting" the program that's in the ECU to your laptop. You only would chose "Send to ECU" if you had made changes offline, and then want to upload those changes to the ECU. You won't be doing that.
When you click the “USB Link” and are online (Button will say online), a screen should appear that compares the files in the ECU with the file in your laptop. They will not be the same because the ECU has learned. You want to click the "Get from ECU” button at the bottom of this screen. This will send the ECU program to your laptop.
Ok Rich..I will try that tomorrow... its running
90% better now with the new O2 and the learn stage
on... the idle seems high yet but I'm hoping that if
it learns more the idle will come back down...its about
1200-1300 when it should be 1000.. but it does seem to
be dropping slowly..... thanks
Edit
almost all the time that screen thats comparing...
it times out... thats when I get that small
might mess up box...the (I forget) but something.. I
have a choice.. yes or cancel..cancel does nothing but
keep the compare screen open
