The tire can be 1" from the frame. I've run closer than that but wouldn't recommend it. I like the track locator bar between the ladder bars. A panhard bar would shift the rear end side to side throughout its range of motion. The track bar keeps the rear end square in the chassis. The panhard bar would also have to be readjusted whenever you change ride height to recenter the rear.
