Update, replaced the fusible link and cleaned the wiring. Car still will not start at the keyed ignition switch. With the key in the on position I jumped the relay and the car started. Once the motor is warmed up I put it in gear and the motor dies. I did this with reverse, D, 2nd and 1st. Also dies in neutral. The contacts on the bulkhead fitting are cleaned and I put a dab of dielectric grease on the contacts. I'm now stumped on where to go next. All the wires that I've looked at are in good shape
If dying in neutral, what gear are you starting it in? Has to be in someplace when started.
Starts in park, when shifted elsewhere it dies ti include neutral
My bad, thought you said the 64 and down push button trans
It's still cable shifted
“So if it’s on the internet it must be true”
Abe Lincoln
