Ok, Started last week. Parked the car and put it in park. Park didn't engage and car started to roll. I hit the brake, the car stopped and I then shifted to 1st and then back to park. The shift indicator is off P, R, N, D, 2nd, 1st. The next day it started ok and drove it to the drug store. Came out and no start. No start from the ignition switch, only power to accessories and only clicking from the solenoid when I jumped the relay. Towed home
Today changed the starter, starter relay and positive battery cable. Cable was bad and the positive post on the starter was real loose.
No start from the ignition switch, with the ignition switch on jumped the starter relay, car starts. Go to put it in gear the starter dies.
Also, absolutely no power from the ignition switch, gauges, power windows etc.
I ordered a new ignition switch. Also the fuse box connections were corroded. Pulled all the fuses and cleaned that.
It think the shift cables are out of sync. The FSM says they need to be adjusted in order for the ignition system to be energized.
I had this same problem with my 64 Dart
