Are you starting it with the throttle partway open? If so try pumping the throttle half way twice and then take your foot completly off the gas pedal and start it, that will, should, allow the carb linkage to set up on the fast idle cam. The choke pull off will make the fast idle linkage not work after the motor is started unless it has the throttle already closed scope thumbs
