And that 3.78" bore $300 block is good for building a 400hp 327. That's all.
What? The LS? Factory blocks and bottom ends are good to 4-digit horsepower numbers Na/Nitrous. RHS/Warhawk LS aluminum blocks are like 2500hp boosted engines. There's plenty of small bore iron blocks 4.8/5.3 pushing na and boosted pushing 650-1000hp. I know a guy that just built a 5.3 LS with a 88mm turbo in a Mustang and it lasted only a couple passes. Ran a best of 7.07 in the 1/8. It threw a rod out of the block.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
