Originally Posted By Crizila
Originally Posted By DARTH V8R
Originally Posted By Street Monkies
Look at it this way. You probably aren't going to go fast enough to need anything more then a flat tappet cam. Plenty of 8 and 9 second cars running flat tappets. I like the rollers as well, but look at the cost difference. Unless you're trying to run way in the 8s, or just anal about having a roller those would be the only reasons I could see why to have one... I really wanted to run a roller in my motor, but at least for now due to cost I am going flat tappet.
guess that's why every car manufacturer today runs hydraulic flat tappet cams.Cause they ain't running 8's.
I just knew this one would come up. Apples and oranges!!
How so?
When it takes more than a sweet mullet to prove you rule at the trailer park..
