If you choose to try the seven quart pan,(or any system for that matter) a 30 psi or higher pressure switch to the oil system and a light you can't ignore might be worth the trouble. During a run it is not easy to see everything, and a 30 psi or higher switch will let you know if there are issues with your setup. Put it next to the oil pressure gauge.[/quote]
Thanks greg thats sound advice i just ordered one off ebay
Check out this item I found on eBay:
http://pages.ebay.com/motors/link/?nav=item.view&id=311567553384&alt=web
