Well, my 64 318 uses a front sump oil pan, FWIW.
The frames up to 1968 are different than the later ones. What worked in a '71 may not work in a '67.
The power steering is difficult to say the least. The factory power steering is junk, also takes up so much room in the wheelwell.
The front clip from a '73 or later ishas been done.
The Crown Vic/Grand Marquis/Town Car 2003 and up IFS setup is the slickest and probably easier than trying to adapt PS to the solid front axle.
R.
