Originally Posted By haddixj
Just curious when you cut the holes how does it not mess up the grid?
The leads run up the sides of the heater. That's why I specified not cutting the length of the heater.
Each of those diagonal lines run back to the sides. There are no perceived cold spots in the pad.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
