Im concerned with splitting a lot of things...cylinders, cranks, rods, axles, transmissions...
I do know that the December Hot Rod has a procharged lowdeck in it and they made 1400 horse and I know for a fact that that motor saw TONS of dyno pulls...the only problem they had was cap walk which was never mentioned. I hope I got rid of that problem with the girdle and aluminum rods and caps...
The supercharger store has made 1700hp with a stock block, but they broke a rod when the motor detonated because of an fuel injection issue...
Im going to try to make 1000 at the rear tires once, then tune it back. Hopefully she holds...
Im not knocking your build at all, sounds very nice. But... sounds like you have a ton of money in just the block, why didnt you just get a aftermarket Iron one? You would half to have near what a new one would cost.
BTW I would love to build a Big inch Mopar on boost...I will be looking forward to your progress.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
