The Block is a Dunnuck one off high performance 400 1971 230 casting.
Block is 1/2 filled
BCR Girdle and Caps
Bill Miller Rods
Eagle Crank
Diamond Pistons with ceramic coated tops and moly coated skirts
tool steel pins
Little port work on the heads
Titanium retainers
Comp 947 springs
Comp Custom Grind Cam .715 lift [Email]248@.50[/Email] 114 centerline
Car weighs around 3200 lbs
28x13.50 MT Et Streets as you can see...
The rest of the details are still undecided...
