Im concerned with splitting a lot of things...cylinders, cranks, rods, axles, transmissions...
I do know that the December Hot Rod has a procharged lowdeck in it and they made 1400 horse and I know for a fact that that motor saw TONS of dyno pulls...the only problem they had was cap walk which was never mentioned. I hope I got rid of that problem with the girdle and aluminum rods and caps...
The supercharger store has made 1700hp with a stock block, but they broke a rod when the motor detonated because of an fuel injection issue...
Im going to try to make 1000 at the rear tires once, then tune it back. Hopefully she holds...
