Quote: K56 is a pretty mild cam, 224 @ .050 barely more than stock, doubt you'd be wanting a race calibration on the carb...
Road Demon & that CH4B wouldn't be a bad combo, but again all demon carbs are known for dirty assembly so you should tear it apart & clean it before using it...
I just did some research on the road demon and found this--
"Available in 625-cfm and the new 525-cfm and 725 models, the Road Demon™ is perfect for small displacement V8s or V6 engines. The Road Demon™ 625 targets mild performance engines from 302 to 400 cid, and rated at 250-350 horsepower."
on a 440 ci mild performance engine, it would seem I need one step up from the road demon wouldnt it?
