How well do you want this thing to handle? I agree with the big Torsion bars, I would recommend the 67-72 Hotchkis bar, no matter which k member you use. What are you doing to the rear end? If you are going with leafs, you need at least a 200# spring rate, and the biggest rear bar possible. If you really want to run against the big boys, go custom 3-link...
