Ok I fixed the rear main oiling hole this evening not to bad just put the main cap in the mill and made a slot to the oil hole in the main line up with the oil pump feed hole.
Yes I will finish this engine, I am taking my time checking everything I can think of. If anyone sees something that there might be a question on please say something. I figure out some way to check it.
