I'm a bit concerned about what looks to be a casting flaw in that threaded hole in the pass side valley wall...
Yes sir there was a problem with the pipe threads on the inside lifter wall, we just drilled them out and tapped them to 1/2 NPT. the original size was 3/8NPT.
