This is my first post here so hi to everyone. I am working on a new 420 cid small block with a Ritter aluminum block. the heads will be RFD W9RP heads, crank is 3.875 stroke with 6.300" long Oliver rods. and Ross flat top pistons. Not sure if the pictures are attached.
