Are you bushing the lifters ?????will the lifter uncover the oil hole when its all the way at the bottom or all the way at the top.THIS is another big problem.... if so bushing the block is the easy fix... I would pressurize the water aND oil before I did anything..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
