Originally Posted By Crizila
.023 wire. Machine screw flat washers on some, but with that many holes to fill, why don't you just cut a new panel and weld it to the hump area? Gonna be a lot of work to make it flat.
Why would I want to make another one? Other than the extra holes there is nothing wrong with it.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
