383cui with original stock 2 barrel carburetor
I´m searching for new carburetor and consider go for 4 barrel.
An option might be the eddy 1406 600 CFM & has electric choke & get the strip kit for it. The one I had was flawless on a 318 DD after I richened the cruise step a bit & fuel psi must be kept low. The performer RPM intake. Another good idea would be as said one of the new carbs that has the adjustable metering systems especially if you are going to use am LM2 to get spot on metering
