Ron, you know I like your car and set up ! But with a bench seat you have to raise the shifter up , no problem , plus I use a Hurst T handle with lineloc button . That I think would be a problem . I have used the 1/4 stick style shifter in friends cars and was happy with it .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
