Thumper ,
I run the Pro Matic II shifter,since 2007/8, and that is my biggest bugbear , inability to get good/correct adjustment and whenever I pull the pan the adjustment goes out
I do like the PPP but after mocking up off VC360's dimensions that will not fit with the bench seat . [censored]
Fitted a Hurst 1/4 stick in a friends Roadrunner , with buckets , about 15 years ago been fine never even melted a cable .
A mate has a 1/4 stick in his 65 Belvedere , mounted on a raised bracket , has bench seat , seems ok I have replaced 1 cable but with better shielding seems fine .
Just fitted a ProRatchet yesterday in a Holden ute with T400 - wow that is a sweet feeling shift .After I race this weekend , Mopar Sunday , I may have to look at 1 and just make a raised bracket to clear the bench seat .
I would like to keep my Hurst T handle with line lock button , so a ratchet seems the go.
thanks
Tex
