Yeah those other two combos are good example too. Nice to see them. Wow 30 lbs on that block is impressive. How many passes on that combo? The avenger made a nice pass in that video
Brian- the heads have been clearance as much as possible. I will definitely mock the rockers up. I am thinking I will need an offset lifter not sure what my options are? I plan to pushrod oil and oil each lifter individually. Also I want to run 7/16 pushrods but I'm not sure if that's gonna work out. Most likely on the exhaust but I would like to have them on the I take side too if posaible
