I am starting to work on my boosted 540 again and was looking for a little motivation and experience. Lets hear your combos even if they have been up before. How much boost? what type of induction? what fuel? engine specs? car specs and et if you want to share that.
my build again is an indy low deck block half filled bored to 4.505
oliver maxx rods, callies 4.25 crank, custom diamond pistons
b1 original heads with titanium intake valves and inconnel exhaust valves.
bullet cam, plan to run t and d 1.8 individual shaft rockers, still need to get springs spec'd.
alcohol dominator by c&s
precision 114 turbo with 1.5 housing
plan to run 30 or so pounds of boost and see what it will make.
lets hear yours the good bad and the ugly
thanks
